PRODUCTS NAME :Bead wire machine
PRODUCTS INTRODUCTION: This is for bead ring making .
MATERIAL AND PROCESS FOR THIS : DIFFERENT PART USE DIFFERENT MATERIAL .
PRODUCTS FEATURE AND APPLICATION:
1 Optimum designed speed and mesh type rotor can satify user's different processes requirment.
2 Compared with traditional machine, feeding speed can be controled well . also the bead ring size can be set easily .
3 Compared with common type, reduce equipment running noise and dusty .
4 More stable for wiring uniformity.
5 Rotor end adopts hydraulic seal. consistent pressure for four ends.
CERTIFICATION: ISO19001-2016
SIZEMATERIALPROCESSLIFEPurposeCertificationOthers
From 8 INCH till 57 INCHCasting alloy steel and forged steel.CNC TURNING.
AS LONG AS YOU WANTBEAD RING WIRE MACHINEISO19001-2016Tyre Making Machine manufacturers
website:http://www.ray-industries.com/rubber-ma ... g-machine/
