銆怳se銆?/strong>
The disposable surgical gown is made of high-quality SMMMS non-woven fabric, which is breathable, anti-bacterial, and anti-permeable. It can be worn and used by medical staff in various operations. It can effectively prevent cross-infection and protect the health of medical staff.
銆怣aterial銆?/strong>
Made of high-performance imported SMMMS non-woven fabric. SMMMS non-woven fabric is an advanced composite non-woven fabric, which is composed of two layers of spunbonded non-woven fabric and three layers of meltblown fabric. The middle meltblown layer is composed of ultrafine fibers, which has the perfect effect of filtering microorganisms and particles; the inner and outer layers of spunbonded non-woven fabric are used as the physical structure basis. After hot rolling, the cleanliness is very high, and no debris and fiber.
銆怢evel銆?/strong>
By choosing SMMMS non-woven fabrics of different thicknesses and with different sewing processes, our company can provide surgical gowns of various grades from AAMI-II to AAMI-IV. For surgical gowns of the same level, reinforcing pieces can be added to the front chest and upper arms to make a reinforced surgical gown to provide additional protection for special parts, which is more flexible and economical.
銆怌utting design銆?/strong>
銆怭ackage銆?/strong>
Sterilized paper-plastic bag packaging
It is suitable for occasions where sterility is required such as the operating room. The surgical gown is packaged in a paper-plastic bag and then sterilized by ethylene oxide gas, and is subjected to harmless analysis according to the prescribed procedures to meet the standard of aseptic use.
銆怚nstructions銆?/strong>
After opening the disinfection packaging bag, first use a paper towel to clean your hands. Use your hands to directly reach into the sleeves on both sides (this clothing is reversed and tied at the back), respectively stick the Velcro on the collar and tie the four on the waist Strap is fine.
SIZE
SIZESMLXLXXLXXXLXXXXL
LENGTH165CM170CM175CM180CM185CM190CM195CM
CHEST125CM130CM135CM140CM145CM150CM155CMWholesale Protective Clothing
website:http://www.yeerprotective.com/protective-clothing/
Our History
>Started production of Silane intermediate:CPTCS in 2007
>Reconstructed into a 100% privately owned shareholding company in 2008
>Process reformation of CPTCS and CPTES,CPTCS supplying kept increasing.ISO9001:2008 certificated in 2008
>Investment in Tricholorosilane production.Started production of Organic-functional silanes and annual sales reached to 20 million RMB in 2009
>The new intermediate workshop was put into production,most of the by-products have been recycled.Silane annual sales increased to around 30 million RMB in 2011
>Silane annual sales increased to 50 million RMB.The new plant start production at the end of 2012(capacity锛?,000 to 10,000 tons/year)
>Silane annual sales increased to 1.2 billion RMB and got the National Key New Product Certificate in 2014
>ISO9001:2018 certificated in 2018 and was rated as a national high-tech enterprise
Our Factory
Our factory is located at Shandong province in north of China which covers an area of 6,700 square meters. The company has 67 employees, including 6 research and development personnel, accounting for 12.5%.We focus on the development and production of silane series products and were called SILANE COUPLING AGENT R&D PRODUCTION EXPERT.
Our Product
HR-69
TESPT
HR-75
KH-550
KH-560
HR-702
Product Application
This product is a multi-functional silane coupling agent which has been successfully used in the rubber and plastics industry. Its application improves the physical and mechanical properties of rubber,improves the tensile strength, tear resistance and wear resistance of rubber, reduces the permanent modification, reduces the viscosity of rubber and improves the processing. Performance. Particularly suitable for vulcanized rubber system with silica or silicate as reinforcing agent. The suitable fillers include silica, talc powder, clay, mica powder, clay, etc. The suitable polymers include NR, IR, SBR, BR,NBR, EPDM, etc. The main application industries are tires, rubber soles, rubber rollers, seals, rubber belts and other rubber products.
Production Equipment
Serial number Equipment name Quantity Remarks
1 Glass-lined reactor 16 sets of liquid production line
2 Glass-lined storage tanks 10 liquid production lines
3 Polypropylene storage tanks 8 liquid production lines
4 Filter 6 sets of liquid production line
5 Vacuum unit 4 sets of liquid production line
6 air compressor unit 1 production workshop
7 Gas boiler 1 liquid production line
8 Double cone spiral mixing unit 1 set of solid production line
9 Horizontal mixing unit 1 set of solid production line
10 1 set of vacuum dust collector Solid production line
11 Automatic packaging machine 2 sets of solid production line
12 Sewage treatment station 1 set of environmental protection facilities
13 Pure water device 1 set of liquid production lineKH-580
website:http://www.yhsilane.com/
Our Factory
Our Product
HR-69
TESPT
HR-75
KH-550
KH-560
HR-702
Product Application
